Best sources for rubber seals
kentvonseverin
Los Angeles
Hello all:
As I get closer to disassembly in order to paint I need to procure quite a few seals. Any advice as to the sources for the best rubber seals would be appreciated.
you need to price them with several people and check availability. a great price means nothing if the availability is zero. you should look at the FAQ - top sources thread ... a couple of places to check. i believe there is a thread in the FAQ on rubber, you should take a look at that to know which rubber you need.
- getbmwparts.com
- walloth & nesch
- BTS
tdgray
Akron, Ohio
Every time I’ve looked getbmwparts.com show absolutely nothing for our cars.
maybe there is a trick to the website?
@tdgray - as i mentioned, the FAQ is your friend here. @Markos did the work for you
