1973 3.0 CS
Peter B
New Member
South Florida
How do i open glove box? It is unlocked and button pushed but will not open.
boonies
Boonies
US - Philadelphia suburbs
Sometimes the glove boxes need a little pull with your fingers along an edge as the button is pushed. Sometimes gravity is not enough as the upholstery around the boxes shifts or flexes over the years creating a pressure point.
Once you have it open you can examine more carefully to see if an adjustment or lubrication of the lock or hinges will be helpful.
Are you sure it's unlocked - tried with the key turned to the other position? Otherwise try Boonies' suggestion and let us know
