4310316 begins
aearch
pleasant hill , ca
itis that
its a full race engine with 11/1 pistons and the b36 oversize valves the works
if it could be done this engine has it
interesting to hear it runng as im running magasquirt 2
sending out the harness to get it all tweaked and then tow it down to the tuner
to set it all up on the computer
redid my original rediator to the 3 core and reverse the in and out
so it will be super simple to plumb
aearch
pleasant hill , ca
Further
Body will be back from shop tnext week then gae all the redone alum and chrome to gether
found the injector plug caps and dist cover got all ther beltsd worked out
aearch
pleasant hill , ca
time
tinkering waiting for the body
what do you think of the colors
Peter Coomaraswamy
Austin, TX
Alan, with an engine like that you can paint it any color you like. I personally go for simple, solid colors- I won't be painting flames on my car :)... But some people do :shock:
aearch
pleasant hill , ca
part time
got all the bolts back and the alum refinished
also did the grille part came out nice
body will be back first of next week
aearch
pleasant hill , ca
Continue
So have the engine setup and detailed
of course had to make a special ac bracket even though it was to stock unit
reversed it so it swung down instead of up
made it from the 6 series alt bracket cut it up
and trimed it out
ready to set it in the body
aearch
pleasant hill , ca
Furthur
Got my stinkin badges from the cities
i was with the dead in 90 in euope
big fun
and all the backstage passes just a few of hundreds
aearch
pleasant hill , ca
Here you go the car is home
Yaaa hoooo
so the fun begins again
pullling everything else to clean and restore
got the c pillers in first thing
aearch
pleasant hill , ca
onward
so its not real preety but the insul is going in ok
a million ways to assemble
im starting from the back
and inside and working my way to the front
also the front window slider has small slots
that fill with grease and dont contract
never knew that one
all kinds of neat surprises.
okguys ill keep posting
