set some foam around the jack mount to keep to quiet protect the jack paint
almost done with the batteries. and the ignition switch
it connects the second battery at start cranking only - ill add some foam to the bottom of the yellow battery tray to
keep the terminal away from the frame , althought its all covered with elephant skin and foam
i have a small quarter size dent in the trunk so will try to even it out and then
replace all the deck lid trim.
also wanted to see what the wood trim would look like on the ac face panel
not to bad lookin- just had some time to tinker.
heres the answer to the detail question in general comments. i painted the inside of the
lug nut opening in the handle and painted the lettering
