bmw 750il leaking oil..
jan
norway and lithuania
hi
i was in germany and drove home a 750il with oil leak from engine,, it seems it comes from left side of engine bay and put some oil on the left sylinder banks.
any ideas before i pull it apart?
thanks
jan
dang
Administrator
Rocklin, CA
Oil leak..
The best thing to do would be to clean the engine really well, drive it a day, then check the engine for oil leaks again. There's too many things that can leak to make a guess..
Dan
dang
Administrator
Rocklin, CA
Re: oilleak
jan said:
with modern cars its impossible to see anything:)
Okay, let me rephrase that! Take the protective covers off the bottom of the engine area, clean it really well, drive it a day or two and check for leaks. That's the least amount of work to get you started in the right direction (in my opinion).
Dan
Ed G
Eastern Connecticut
Oil Leak
Pros use dye that reacts with UV light (blacklight). Run the engine, shine the light........Good Luck either way.
