DIY - LAN. Steering pump renewal process
to put this in an easy to find place...
with the excellent company of T.E.Lawrence aka @Stevehose ....
The mighty steering pump...
pressure valve
one oring
this is from 1970
the target…as Steve-in-kitchen demonstrated…
deQuincey
Quousque tandem...?
some more...
careful, this will fall down when upside down
the seal sits flush with the wall, see the needle bearing below
to extract this one use a proper stick and hit from the other side
to extract the needle bearing and the seal use a 18mm hex vase, and a proper tool to not hit it with a hammer
this setup works very smoothly
if you place a piece of paper pressed upon the cage, the needles will not fall down
Pittraider18
Seattle, Wa
Fantastic write up and photos. Thank you for including the bearing depths etc. within the manual as well as your little notes. Will be bookmarking this for future reference!
deQuincey
Quousque tandem...?
eriknetherlands
Netherlands, Eindhoven area
As this thread is worthy of a nice spot on our forum, after consultation with @deQuincey , i plan on moving this thread to the DIY section.
I will do the moving this weekend - I need to get accustomed to my new super powers first.
  • Like
Reactions: Wes
