How hot does a doff get?
Cornishman
Essex, UK
How hot does a diff get on a road car? This car is driven like i own it,not stole it, so I assume not very hot.
My question is based upon the type of paint to use, ordinary spray can black, Hammerite smooth or VHT SPRAY. Any suggestions? I am not up for powder coat etc, that will take too long, take funds from other parts of the car and mean it can't be a concourse winner!
C
Arde
Cupertino, CA
The only person I can think of that may have a differential temperature sensor routed to the instruments is DQ.
Tierfreund
Duesseldorf, Germany
Yes DQ and the guys with the real Alpinas. Several Alpinas had diff oil temp gauges. Admittedly only in the 80s/90s.
But several diffs have cooling fins so 100deg cels would not surprise me.
Engine block paint would probably be a good compromise. Easy to apply, and engine block will probably get hotter than the diff but not as hot as an exhaust, is good for iron castings and in oily surroundings.
Cheap as well.
Cornishman
Essex, UK
It turned out too Grey
Thanks, but I had already painted in in VHT. OK, but too grey for my me.
So I will see how well it holds up against use.
C
Stefan
Sweden
C
Ok, that was a bit grey :)
As "Polariscsl" above mentioned that Hammerite works fine on these areas.
I could definitely confirmed above after years of driving with Hammerite on callipers and diff.
deQuincey
Quousque tandem...?
VHT has a flameproof line of paints
in my case i use a 750 deg. celsius rated black from rust oleum, i have used in my exhaust manifolds three years ago, and the paint is still there
@arde, thanks for giving me new ideas :wink:
