Like Bill said, there are only two FI related relays in the engine compartment: 1) main and 2) cold start. Here's a pic of them in my car.
And here's the ground point that sfdon mentioned:
There's also a fuel pump relay under the back seat next to the ECU.
As long as the main relay is sending power to the ECU, which it sounds like it is, then I think you can rule the relays out in terms of the noid lights not lighting. My understanding is that the trigger points initiate the injection pulse and then a combination of readings from the MAP and the trigger points (engine speed) determine the injection duration. Like
@sfdon said early on, if there's no noid light flashing then your injectors aren't firing at all.
It seems to me that would leave the ground issue that sfdon mentioned; MAP issues: either a broken/bad connection between the MAP and the ECU, or the failure listed below.
Failure Modes
- Open or shorted primary or secondary coils: Results in no injection pulses, the car is inoperable.
@sfdon - if the the trigger points weren't connected to the ECU or they weren't sending any pulse at all, would that also make the injectors not fire?
