subframe reinforcement?
Bearmw
Western, MA
I am in the process of redoing the front and rear suspension on my 72 Bav and am wondering if the front subframe should be reinforced before I powder coat it? I have an E30 which I reinforced the motor mount areas of the subframe (a known weak spot) as a preventative measure and wonder if the E3 subframe similarly has any weak areas? FWIW I will be swapping in a high compression B35 and I tend to drive fairly aggressively at times and may do an occasional autocross.
On the rear I will be doing an E28 subframe swap.
bavbob
Boston, Ma
In the years of being on this forum and owning an E3, never read that anyone had issues. Aggressive driving in Ma is a misnomer don't ya think ( excluding the autocross ).
Bearmw
Western, MA
Bob thanks for your response and I probably should have said "spirited" driving on some select country roads... :)
sfdon
sfbay area
E9 subframes last until they are driven into concrete blocks in parking lots.
norcal-bav
Bay Area, CA
Yeah, It will be fine, I wouldn't mess with it. My V8 with delrin engine mount bushings has not cracked the subframe. Spirited driving as well.
