We get asked how to install compliance bushings…
Krzysztof
Poland
Looks like the dog was feeling "strong" vibrations and decided to leave.
gwittman
Costa Mesa. CA
When I did mine a long time ago, I recall making some kind of sleeve to pull it in place. I don't remember the details. That had to have been at least 40 years ago.
otter74
Chicago, IL
This prompts me to ask - where did you get those bushings? I can’t find the bushings for my E12 (seem like they ought to be the same as for E9s) in stock anywhere.
From Athens, Greece on eBay a few minutes ago…
very expensive!
bavbob
Boston, Ma
I did this job and it was a bit of a PIA and I used BMW bushings. If I were to do this again I would go poly. Although poly can be harsh, I cannot see that having any major impact here. I did not price them but surmise they would be cheaper than OEM.
otter74
Chicago, IL
All poly bushings, yes. I wouldn't do that on a car like an E3/E9/E12 unless the whole suspension was track-oriented. My 911 has monoballs and polybronze bushings that the PO installed when he overhauled the car, and while I find it perfectly fine for my uses (torsion bars are stock), impact harshness is obviously greater. But radius rod bushings alone are not going to have a meaningful impact on impact harshness on a car like this when control arm bushings, trailing arm bushings and strut/shock mounts are all rubber.
bavbob
Boston, Ma
That was my point, they are ok as thrust bushings but I do not use them anywhere else except maybe the subframe when the time comes.
otter74
Chicago, IL
Yes, agreed. i have OE bushings for the semi-trailing arms whenever I do them, and I'll probably just put IE inserts in the subframe bushings.
