psalex
New Member
Palm Springs, CA
I replaced a stripped driver side rear window transmission.
Fun job, I've gotten pretty efficient with replacing these, it's the third one I've done on that window.
I need to replace my front left and rear left… Any advice? Did you use a five series motor?
Wobdog
a.k.a Mike
Los Altos Ca
Wife asked me to put up holiday lights today. Not sure why she is upset. She should have been more specific
Arde
Cupertino, CA
I can speculate why.
- Front tire seems low on pressure?
- The black decal behind the grill is gray, need to apply Back to Black after waxing the car.
- The US side reflectors can make any wife upset, spouses never liked the Federalization changes
Wobdog
a.k.a Mike
Los Altos Ca
LOVE IT
Getting car paininted next year and doing reflector delete and Black behind grill. I will check air pressure I thought the same
rsporsche
Atlanta, GA
looks quite good! i definitely like the side panels on the fenders. that gives a great finished look ... especially when they are covered with elephant skin
rsporsche
Atlanta, GA
of course you did @Arde ... its all your fault. i have it on good authority that you will receive your portion of the bill in the coming days
burky
Sydney
I PICKED MY CAR UP FROM A LOCAL MECHANICAL SHOP ,I HAD A NEW , LEAKING BRAKE MASTER , AND I WANTED MY MECHANICAL ASSEMBLY WORK CHECKED, AS IT WAS A BARE SHELL WHEN I STARTED, 9 MONTHS LATER I GOT A THUMBS UP ON THE ASSEMBLY AND A NEW MASTER . ITS NOT ALL NEGATIVE , AS I DROVE THE CAR HOME FOR THE FIRST TIME SINCE 86, THAT WAS FUN. I HAVE SOME MINOR ASSEMBLY, AND A FEW ISSUES TO TIDY UP , THEN 2285171 CSL , WILL HIT THE ROAD ,SOOON.
DWMBMW
Miami, Florida
The Emerson Fittipaldi Concours D’ Elegance Key Biscayne​
Attended today with Dirk and Drew.
day66
Manchester, UK
I've been taking advantage of the unseasonably mild weather to rectify a few minor issues:
Firstly, the original starter motor spun the engine over nice and quickly but wasn't engaging cleanly on the first start of the day - I replaced the original with the later type for the E34 M5/535. This might be one job that is easier on a RHD car!
Secondly, "running - in" adjustments, so retorqued the head - the head bolts seemed relatively "loose". A couple of the valve clearances had drifted a few thou wide so were adjusted while I was in there and I checked the spray bar bolts! The points had closed up a little. It took a while to locate the ball on the flywheel but with a dab of paint I was able to see the "ball" and reset the timing with a strobe light.
Mechanically, it's all but there - just an annoying noise from the clutch - hard to describe but it sounds/feels like there is an issue with the release lever/mechanism but i fear it's going to have to come out. Anyway didn't stop me taking it out for a last run of the year....
