Who does enamel?
adawil2002
Brunswick, Maine
I have had much success hand painting old roundels with Testors model paints, lasts for years. Pretty easy to do, no special skills needed. Here's Vern's roundel after I painted it.
Ohmess
I wanna DRIVE!
Aiken, SC
Hi Andrew - my initial attempt at this did not go well, and Steve was not entirely happy with his efforts either as I recall.
But then perhaps I should give it another try.
DWMBMW
Miami, Florida
Hi Chris, Have to thin the paint a little to get it to flow on smoothly.
That makes sense. When I painted my C pillars with Testors, it was difficult not leave tiny brush strokes even with a nice art brush. Unless I buy an airbrush, I will try thinning it next time.
twistinglane
Maryland
Air brush for raised letter roundels sounds good idea. Someone try it out? Need a good protective coating on raised area then.
mulberryworks
Mr. Fixity
Jacksonville FL
It's a minor point, but I ran across this site that states we've been using the wrong name for the process that makes our C-pillar badges.
These enameled emblems are often, incorrectly, referred to as cloisonné. Cloisonné is an enamel process in which separate bands of metal are bent then applied to a base. These labor intensive bands encase the enamel and create the design. I have yet to see an automobile emblem done with cloisonné. The process that is used is called champlevé (pronounced shomp´-leh-vay).
The champlevé technique involves applying enamel into depressions in the base metal. These depressions may be etched, engraved or, in the case of automobile emblems, die stamped. The stamping process can also include the beautiful design work that shows under transparent enamels.
Historically the word enamel meant glass but today it seems to refer to any shiny color. The correct terminology is vitreous [glass] enamel. It is a true glass that melts and fuses around 1400 degrees F.
Enamel can be obtained as opaque, translucent or transparent. The colors are created by the addition of metallic oxides to the glass. The most common form is ground to #80 mesh and looks like colored granulated sugar. These enamels are formulated to molecularly bond with copper, silver and gold.
