Wiper arm questions
FinnCoupe
Finland
I'm working on 2800CS -69 wiper arm system.
Going to clean it and fix any loose joints.
First I need to take it apart without breaking anything....:-D
Has anyone disassenbled the first and second joint after wipermotor?
First joint. Looks like plastic cap? Don't wanna break it while trying to remove it wrong way...
Second join, looks also plastic.
deQuincey
Quousque tandem...?
those are plastic yes
in my experience you can not remove them from the metal part, what you can do is to remove them from the articulated ball that belongs to the other part
the best way is to use two flat screwdrivers placing them between the two metal parts, one placed at three and the other at nine, you just place the one at nine and keep it there while gently turn the other screwdriver until the cap pops out
it is very easy
FinnCoupe
Finland
Thanks, didn't break anything.....yet.
I thought that it was just a plastic cap but it goes thru the arm.
Here all parts of the joint.
