seriously considering trying to get a wooden tab rail fabricated and installed in a lhd CS. Anyone have one for sale that i can try to use as s template?
Hi Steve. Is the grab bar on the E9 the same as the 2000cs,except covered in vinyl?
I have a bare wood bar from a 2000cs,actually I have two. If so than by taken off the top half horizontally all that wood have to be done wood be to scallop the top. Am I correct?
One solution for a LHD car might be to strip the vinyl from the top half of the piece, then treat the exposed wood underneath. It will achieve the look and feel without the fixing problems. As there is a strip along the front, there is latitude for errors to be covered up. Just a thought.
Harry,Hi Steve. Is the grab bar on the E9 the same as the 2000cs,except covered in vinyl?
No it is not. As mentioned by others, it is a completely different piece. There is a steel frame covered by foam, and the whole thing covered with vinyl.Is the vinyl grab rail on the rhd coupes just a wood one (like rhd) but covered in vinyl? Like this photo shows?
This is reportedly stock from a lhd car.
That is correct. The problem is that the internal steel frame does not lend itself to adding the wood rail to it. You have to use a router to carve a channel inside the wood rail. Because of the compound curves involved, it is not an easy task.It loos like the usa dash piece would have to be hacked in half lengthwise then the wood attached and the seam covered by trim. Imho the only detail missing on the usa cars that would make the interior even more beautiful is this wood piece instead of vinyl
