In addition to the stock battery to fender strap, I have battery to alternator case, alternator case to block, and valve cover to firewall strap.
I also ran another strap from the valve cover to the firewall, but I like the fender wall to oil filter idea.
I was chasing a bouncing temp gauge, and as a result of all the grounds I fixed my bouncing fuel level needle.
Damn temp gauge still goes nuts every now and again, so I need a new gauge, but at least I'm well grounded.
this is next on my list - to use the other piece of coupe jewelry (Luis' regular flat strap) and tie the alternator to the engine. i also have the firewall to valve cover ground.In addition to the stock battery to fender strap, I have battery to alternator case, alternator case to block, and valve cover to firewall strap.
the common grounds inside of the dash need to be checked every now and then to make sure it hasn't loosened up. if the grounds are tight, look for a shredded wire that is rubbing on a piece of metal back there.Check whether your gauge is grounded to a common ground location, or separately. A consolidated ground is best.
Close your eyes. Breathe deeply. Pour a shot. Then call the neighborhood kid with the skinny arms and little hands to do it for two bucks.
Arde,
You are obviously well grounded.
Chris
There should be a 7th spark plug wire that carries the ground circuit for the spark plugs.
Even a 7th dummy spark plug that is made of solid copper to attach that wire to.
Like many other useless concepts, you heard it here first.
