Henrik Ekroth
New Member
I checked the fuse in fusebox and its ok, i understand these two are powered by same source, dont know how to proceed. Have anyone else seen this problem on your E9?
Henrik
Henrik
e9coupe.com
THATS COOL YOU USING MY WIRING DIAGRAM
SO TO THE PROBLEM
SO FOLLOW THE PATH OF POWER AND OF COURSE YOU CAN CHECK THE RELAY
EASY. SEEMS TO BE THE POWER IS NOT GETTING THERE - IS POWER IS THERE WITH A QUICK CHECK AT THE END THEN IT HAS TO BE THE MOTOR
ALTHOUGHT IS BOTH UNITS DONT WORK IT HAS BE THE POWER PATH.
JUST GET AN OMNMETER AND GO THRU IT
YOULL FIND IT THEN
e9coupe.com
