What are the TOP SOURCES for PARTS and SERVICE?
We tend to repeat information within threads, so perhaps it would be a good idea to keep a running list of where to find things. I will be adding more things to this, and editing / adding based on comments.
Restoration
Engine Building
Transmission Rebuilding
Specialty Driveshaft / Driveline Mounts
Differential Rebuilding / Parts
General Restoration Parts
General BMW Parts / OEM
Body / Sheet Metal Replacement Parts (New)
Body Rotisserie
Fiberglass Specialty Parts
Specialty Parts (New)
Used Parts
- La Jolla Independent (USA) - www.bimmerdoc.com
- Coupeking (USA) - www.coupeking.com
- Al Taylor (USA) - [email protected]
- TomHom (Germany) - @TomHom
- CSi Inc. (USA) - www.bmwclassicparts.com
Carburetor Parts / Rebuilding
Eurocarb (UK) - https://www.dellorto.co.uk/
- Carburetor shop (USA) - http://thecarburetorshop.com/
- Paltech <rebuilding> (USA) - http://paltech1.com/carb-rebuilding/
- Weber carb linkage (USA) - https://www.2002sonly.com/ - @halboyles on e9coupe.com
D-jet Fuel Pump / ECU + injector service
- Fuel Injection Corp (California - USA) - http://www.fuelinjectioncorp.com
Exhausts (Stainless Steel)
- Fritz's Bits (UK) - www.fritzsbits.co.uk/
- Walloth + Nesch (Germany) - www.wallothnesch.com/
Exhaust Headers / Manifolds
- ACP Headers <Stahl design> (USA) - https://acpheaders.com/
- Cybox (UK) - www.cybox.co.uk
Wheels (New)
- 14" Alpina (New) - Walloth + Nesch (Germany)- www.wallothnesch.com/
- 16" Hardy + Beck (USA) - https://hbkarmakanix.com/bmw-classic-tuning-parts/
- 16" Coupeking Alpina (USA) - www.coupeking.com
- Alpina Lug Nuts (USA) - www.coupeking.com
- Alpina Magnesium wheel centers - https://www.cckhistoric.com/shop/Group-2-BMW-3-0-CSL-c2561005
Wheel Refinishing / Custom Wheels (especially BBS)
- Ehrlich Wheel Works (USA) - http://ewheelworks.us/
Vintage Tires (New)
- Longstone Tyres (UK) - https://www.longstonetyres.co.uk
- Coker Tires (USA) - https://www.cokertire.com/
- Lucas Classic Tires (USA) - https://www.lucasclassictires.com/
A/C components
- SFDon (USA) - excellent kit, including hoses, dryer, compressor, mount, fan, condensor - (@sfdon on e9coupe)
- Nostalgic AC (USA) - https://nostalgicac.com/
- Vintage Air (USA) - https://www.vintageair.com/
- Ice Auto Air (USA) -iceautoair.com
- Evaporator kits - @Blinkling
- Layne Sanden bracket - https://lcwylieco.bigcartel.com/products
- Cold Hose (USA - FL) - coldhose.com - hose, fittings, other parts
Suspension Parts
- Paul Baker (UK) - lowering springs - @Paul Baker on e9coupe
- Suspension Techniques (USA) - sway bars - http://www.stsuspensions.com/
- Ireland Engineering (USA) - https://www.iemotorsport.com/
- Hardy + Beck (USA) - https://hbkarmakanix.com/bmw-classic-tuning-parts/
Coilover Suspension Kits
- RAAB / KW v3 - Mario Langston at VSR (USA) - www.vsr1.com
- BC Racing - https://shop.bcracing-na.com/products/69-74-bmw-2500-3-0-cs-new-six?variant=19702521888856
- GAZ Shocks (UK) - https://www.gazshocks.com/
- Ground Control (USA) - https://groundcontrolstore.com/collections/e9-e10/products/bmw-e9-complete-coilover-system-2
Brake Component Rebuilding
- PMB Performance (USA) - https://www.pmbperformance.com/catalog.html
- Rebuilt Caliper Headquarters of America, Graem Elliot (USA) - https://www.caliperhq.com/
- White Post Restorations (USA) - https://whitepost.com/#hometop
Blue Braided Brake Hose
- Belmetric (USA) - https://belmetric.com/m7x13-5-blue-braided-european-oem-hose-rh7mbn/
- California Import Parts (USA) - https://www2.cip1.com/vhd-n20-3501/
Rear Brake Regulator Rebuild kit (Same as a VW/Porsche 914 kit)
Power Booster Repair
- Power Brake Exchange (San Jose, CA) - http://www.powerbrakes.com/
- Tii Boosters (USA) - https://www.2002sonly.com/ - @halboyles on e9coupe.com
Power Steering / Hydraulic Repair
- Jay Stratton (USA) - [email protected] - www.jaysbmwparts.com
Pebra Key cutting / cylinder re-key
- Santa Monica Lock + Safe (USA)- Blaine (310) 450-5101 - https://www.santamonicalockandsafe.com/
- Keys4classics (Australia) - http://www.keys4classics.com/
- BMW - you can order new keys for your locks (need - Proof of ownership / Key code, should start with GC, off of your original to the car from BMW key
RHD Servos (Booster) Seal Kits
John Hudson : [email protected]
Metal Refinishing
- Speedway <Polishing / Ceramic Coating> (USA) - http://www.speedwaypolishing.com/home.html
- ASCO <Powder Coating> (USA) - https://www.ascoweb.com/powder-coating/
- SSS Restorers <Trim restoration> (USA) - https://www.facebook.com/SSSRestorers/
- Salt Lake Chrome <chrome plating> (USA) - http://saltlakechrome.com/
- Metal polishing / plastic restoration> (Mexico) - https://sssrestorers.com/
- EMF Plating (Florida) - www.EMFPLATING.COM 954-446-4143
Metric Fasteners / Electrical Fittings / Clips
- Bel Metric (USA) - www.belmetric.com
- McMaster Carr (USA) - https://www.mcmaster.com/
- Clips and Fasteners (California, USA) - www.clipsandfasteners.com
- Electrical Connectors (USA - Chicago, IL) - https://connectorexperts.com/
- Prancing Moose <Dave's Volvo Page> https://www.prancingmoose.com/blackvinyl2.html#headlightplugs
- Mouser - https://www.mouser.com/
Wiring Harness - wire
- Striped wire for harnesses (USA) - contact Len 978-255-7114 https://4rcustomswire.com/
Lighting
- Daniel Stern Lighting (USA) - www.danielsternlighting.com
- Mo Brighta <tail light improvements> (USA) - Mo Brighta on e9coupe
Universal Weatherstripping
- Steele Rubber (USA) - https://www.steelerubber.com/universal-parts
Wiper Arm Bushings
- White Engineering (Ireland) - https://wiperrepairs.com/wiper-bushings/ <buy 3 - 12A and 1 - 16B>
Carpet + Upholstery
- GAHH (USA) - https://gahh.com/
- World Upholstery (USA) - http://www.worlduph.com/
- Klaus Hermann Mayer (Germany) - https://cabrio.de/
Interior Finish Materials
- Veteran Company (USA) - http://www.veteranco.com/
- Global Upholstery Supply (USA) - http://globalupholstery.com/index.html
- Albright's Supply <trunk materials> (USA) - https://www.albrightssupply.com/
Recaro / Scheel Materials + Parts
- Aardvarc (Bonita, California) - 2002parts.com
Upholsterers / Interior Specialists
<California>
- Juan Ortiz (Costa Mesa, CA) - VERY highly recommended, but completely (perpetually) overbooked
- Westminster Upholstery (Anaheim, CA) - (714) 632-5040 - Pete is the Owner
- Freddie Auto Upholstery (San Francisco, CA) - (415) 695-1325
- Sang's Custom Auto Upholstery (Merced, CA) - (209) 658-8586
- Sidco Custom Upholstery (Mountain View, CA) - www.sidcocustoms.com
<Vermont>
- Richmond Auto Upholstery (Richmond, VT) - www.richmondautoupholsteryvt.com (802) 434-3888 VERY Highly Recommended / Award Winning
<New Hampshire>
- Turner Upholstery (Rye, NH) - http://www.turnersupholstery.com/
<Florida>
- Naples Upholstery (Naples, FL) - www.naplesupholstery.com
- Shamrock Auto Trim (Miami, FL) - (305) 944-3621 - Lee McPherson
Leather Refinishing Supplies
- Leatherique (USA) - www.leatherique.com
- Color Plus (USA) - https://colorplus.com/
Dash Wood
- Bela (EU) - Bela22 on e9coupe.com
- TomHom (Germany) - @TomHom on e9coupe
- Madera Concepts (USA) - http://www.maderaconcepts.com/
- New Wood Dash bottom (USA) - www.coupeking.com
- Dashboard Reproduction - Suit-Up Classics (facebook)
- Wood Medic Romania - https://www.facebook.com/woodmedicr...b6XseX4qOqki-RlYel2YggLt9-sNIsF7e9jpk-YQ&_rdr
Wood Speaker Grilles (NEW)
- @TomHom on e9coupe.com (Germany) - post #35 https://e9coupe.com/forum/threads/ive-got-wood-veneer-let-me-see-yours.44561/page-2#post-392616
Ran out of room in the previous 2 posts, so i have added a new post for interior items.
Steering Wheels
- bespoke steering wheels + parts - @Wladek on e9coupe
- Petri Hub adapter - https://www.patipatina.com/portfolio/petri-steering-wheel-to-momo-hub-adapter/
Shift Knobs
- Alpina + non-logo (USA) - www.coupeking.com (check ebay store)
- Custom wood knobs (USA) - www.customwoodshiftknobs.com/
Speedometer / Clock Repair
- North Hollywood Speedometer (USA) - https://www.nhspeedometer.com/
- Palo Alto Speedometer (USA) - http://paspeedo.com/
- Overseas Speedometer (USA - Austin TX) http://speedometer.com (one member asked for a quote on an e3 speedo and was turned down)
Seattle Speedometer (USA - Seattle, WA) http://seattlespeedometer.com
- Specialty Gauge - Cory Shepard (USA) www.specialtygauge.com Phone 703 402 4008
Used Literature + Manuals
- Faxon Auto Literature (USA) - https://www.faxonautoliterature.com/
Added section for upholsterers with several recommendations in California, the NE and Florida. if you have any that you would recommend, please start a conversation with me. thanks!
I ran out of room in the original 2 posts within this thread, so in order to add more links - i have created a new post for Interior related items ... removing them from the previous.
