So since I bought the E24 and put it back on the road after 20 years I have been discovering the joys of getting slightly crispy cars on the verge of needing a LOT of work, taking an educated gamble and fixing up to an acceptable level and just enjoying it.
Latest was a MK4 Golf R32 that had been turned into a full show car and then laid up for 5 years. Promptly returned to as close as I could do standard however it was always needing something. Now constant maintenance I can deal with, however the fact you need to take the front end off to do pretty much anything (bumper off to change a bulb) or be blessed with incredibly small hands meant that the hunt was on for something a bit more vintage.
Was offered this E28, a genuine dogleg manual M535, March 85 built only chassis number 0019 of DC72 type production. Zinnobar red with anthracite cloth, a surprisingly solid car with minimal rust on the O/S wing and a few surface scabs here and there. The metrics are long gone and some RC090s are there which I will keep, probably refurbish before I get fresh rubber. Car has been sitting since COVID when it was dismantled somewhat as a little project then left. All rubber hoses need to be changed, at the same time will do water and fuel pump, viscous fan, clean the injectors and give it a full service.
