Wanted: Looking for E28 window motors for rears
e9Leveque
Seattle, WA
Hoping that someone has some E28 window motors kicking around that they'd like to offload. My rear driver window isn't working and I figure if I'm going to take the area apart to fix that then I might as well upgrade both sides to a more modern configuration.
you do know, its not a direct swap - right? you will have to do metal cutting and rewiring. if i was going to take a window apart, i would
1. read about removing the screws at the front of the window. take a lot of pictures. don't undo anything that you don't need to.
2. before you undo any mounting screws, i would first take a marker and clearly indicate where the mechanism sits (alignment marks at all mounting / adjustment screws). realigning these things is an art. take the rear window out by undoing the 2 most inward mounting screws (simple mounts - near the rear seat) - ones that don't move the window in 4 directions.
2. once you've taken them out - clean all of the dried / hard grease out of the tracks / wheels and the sardine can motor - you want to make sure everything moves easily. soaking things in gasoline helps remove dried grease. once clean, re-grease everything with a good synthetic grease
3. put it back together and replace any rubber that is cracked or torn.
Yes, I know that it will be a bit of a job. I think I am up for tackling it, but I do appreciate you emphasizing that I should make marks showing the current state of the windows to make re-assembly a bit easier. Unfortunately my driver side manual front isn’t quite aligned (doesn’t go up fully) so that one I’m going to have to massage a bit to figure it out. Thankfully people like you have written up the steps on the forum, but I’m suspecting I’ll be reaching out for guidance during the process
