Rough idle issues and Carb gaskets
chope97
Silver Spring, MD
Today was a beautiful day in the D.C. area. I drove my car to the exhaust shop it drove well and it was nice and fast but the idle was not good. When I got back I decided to check the timing. My car has no ball or marks on the fly wheel that can be seen from the little hole. I adjusted it by ear and watched the idle go up or down on my sears tune up box from the 70's. It was running better but not where it should be, next I decided to check the cabs to see if they were in sync. Turns out they were a little off but I could not get them to adjust. I decided to spray some carb cleaner at the base of each carb by the spacer. One carb got no reaction. The other carb by the firewall caused the idle to go way up. Question, I have taken the carbs off before is there something better than the cardboard gaskets I can use that will seal better? Should I use two gaskets together? Should I use gasket seal?
P.S I also found that the on the manifold closes to the firewall the vacuum port that had a cap on it the cap had come off so this was causing a big problem also
Usually one paper gasket is enough. I would check to see if the surface is cklean and the crb base is flat. Once you have the vacuum cap back on you should check again and pay attention to the throttle shaft area.
You may want to clean and lubricate the linkage so that each carb can be adjusted to come off the fully closed throttle plate together.
This was a common problem with the Zenith's. 40+ years ago I used a wet/dry sandpaper on a piece of glass to sand the cab bottom mating surface perfectly flat. Same with the spacer blocks.
Yep. Agree with Sven. I have 2-32/36s on my M30, and went through all this vacuum leak stuff and sundry other gremlins several years ago. Tightening down the mounting nuts did not help me feel I had taken up any gaps at the carb base. And these Webers are old! So, removing both carbs, placing them on sheet of glass, sanding just a bit, then using a light to see if there was still any leakage, then finally removing a bit more material. New gasket, and finally a satisfactory fit. I will add that I also replaced the throttle shaft bushing in both carbs as this is a typical wear/leak area. Good luck, and let us know what worked.
I had a rough idle issue a month or two ago. Make sure to check your idle stop solenoids are functional properly. I took mine out and cleaned up up with some carb cleaner since they were clicked on and were getting 12v. Try getting that timing in order using a timing light. Sounds like you have a vacuum leak at the base though. That ought to be your main culprit though.
Update, got car running real well, plugged vacuum port, adjusted timing, it was running sweet. Then it started loosing power, then it would pick back up. Seemed like it was running out of gas, tank is full. I swapped in a new gas filter, then a new fuel pump from my parts stash. It starts right up ran well but then the power lose came back. If I stopped at a stop light power would come back seemed like the more I drove the more the power lose would come back. Next I checked the coil it was out of spec for ohms. I reached into my parts depot and got a coil swapped it in once again car started right up then ran well for a while. Got it back home, checked everything again, now I am thinking it is my electronic ignition system. When you start the car it uns well then after a couple of miles of driving it starts to loose power. Currently there is an Allison Electronic Ignition module in it not sure how old it is. I just order a new Pertronix kit. Any thoughts?
Have you checked your timing with the timing light again? I run an Allison E-Ignition as well. It's nearly impossible to time properly my feel/ear. We are talking a cm or two too car clockwise or anti-clockwise will throw it off.
I would recommend trying timing properly before your rip and replace with the Pertronix.
What plugs do you have in the car? Platinum plugs were NOT the way to go for me. Opted back to a stock-like copper NGK plug and those have been working flawlessly for me.
Thanks for you response. My car has no ball or timing marks on the flywheel as far as I can see so I can not check timing by the normal method. I have copper NGK plugs. My car runs fine until I have driven it a few miles then it starts to loose power. If you stop at a light the power may come back So this is an intermittent problem.
