Anyone found a good source for the top door seal piece?
$300.00 for entire seal from Germany... hurts a bit..
entire top seal for 300 bucks or entire door seal for 300 bucks? 300 bucks for the whole thing is a good price. if you need just the top piece, i might have one
We don’t use the bottom section- there are better seals than factory
Just out of curiosity, where does one find those better-than-factory bottom seal sections?
at Steele rubber on line or at my shop
Thanks Don. Currently running a Steele profile, but it has to be the wrong one, because they don't work great.
Believe it is the bulb type instead of the molded-on extrusion thin side lip design, but there's no room to even see it in the garage at the moment. Do you guys have success with one of these profiles, or is a different one altogether?
https://www.steelerubber.com/side-bulb-push-on-seal-70-3592-99#70-3592-99
