a/c drain
i am circling back to what people are using for the a/c drain inside the car
downside, the 64511356039 drain plug is NLA ... so the search for a drain is still on. i might try using the
I used this on mine, some pics on my restoration thread (linked in sig). It's is little flimsy and a little too tall. I had to trim it a little, and lining it up was a pain, but it worked. It clicks perfectly into the tunnel hole though
Hope someone will start 3D printing the 64511356039 drain plug. When I assembled mine, I wasn't aware of the E24 part so I used a plastic funnel with lots of putty. So far so good.
i have been looking at getbmwparts.com and searched for condensate drain. there are some and quite affordable ... just no idea if they will work or not - no picture. the other ones were more complicated and expensive.
the first one is for x3, x5, etc. its a 2 piece thing that clips onto a part in the tunnel - likely a bigger hole.
3D print one. I'll do it for my car when I get there.. If it works, then you can just "pop out" the AC unit and put one in ... :D
yeah, right ... bottom line is you need to have one to know what you need to model / print. if somebody has one not in a car, and can send me some pics + dimensions we can model it.
I think I do have the one I took off my car. I'm swamped at work right now, but I'll check this weekend. The basic design doesn't seem too complex, so presumably easy to print in elastomeric material.
Ready to ship.. where?
I have the 3d printer and can print off some in different materials if someone wants to make the rendering. Thinking I need one of those object scanners…
looks like it has a chance ... if you can get a real MB part number that would be helpful over here
