I've opened up and repaired some of the little stuff on my car (the emergency flasher switch comes to mind), but this particular switch doesn't just snap apart. It is held together with five rivets that would need to be drilled out in order to get it open. And you don't know whether a visual inspection will identify the problem. And even if you find something upon visual inspection that needs to be bent back into place, or soldered or replaced (which would entail sourcing a replacement part), you likely would need to know how current is supposed to flow through this baby in order to test whether your repair was successful. So, you need an electrical diagram and test equipment to make electrical measurements. Then there is the issue of getting this thing back together properly. It appears you either need to replace the rivets and/or source very small nuts and bolts to get the thing back together. I have a rivet gun, and a supply of rivets, but nothing this small. And I have a pretty good supply of nuts and bolts, but again, I doubt I could readily come up with a set of five nuts and bolts small enough to reassemble this part.What is the symptom your old one is showing you? I would open that thing up and have a look inside. You may be surprised how easy it may be to get it back to factory spec. Good luck and report back!
For me, I would really like to have a look. Got nothing to lose. I would drill out those rivets, tap a thread, replace with screws and some Locktite, but it remains to be seen, what is going on inside. That's why I was curious about the offending symptom.I've opened up and repaired some of the little stuff on my car (the emergency flasher switch comes to mind), but this particular switch doesn't just snap apart. It is held together with five rivets that would need to be drilled out in order to get it open. And you don't know whether a visual inspection will identify the problem. And even if you find something upon visual inspection that needs to be bent back into place, or soldered or replaced (which would entail sourcing a replacement part), you likely would need to know how current is supposed to flow through this baby in order to test whether your repair was successful. So, you need an electrical diagram and test equipment to make electrical measurements. Then there is the issue of getting this thing back together properly. It appears you either need to replace the rivets and/or source very small nuts and bolts to get the thing back together. I have a rivet gun, and a supply of rivets, but nothing this small. And I have a pretty good supply of nuts and bolts, but again, I doubt I could readily come up with a set of five nuts and bolts small enough to reassemble this part.
I guess now that shigeta knows where to find a replacement, he might want to risk tearing into his part and seeing what happens. I'm here if that doesn't work out.
For any future travelers reading this thread, the connection between the chassis harness and the transmission gear switch is made on top of the brake booster tube next to the firewall, just underneath where the coolant expansion tank sits.My recollection is that the connection lays under the console on the transmission tunnel, so it doesn't get disturbed once it's plugged in.
The switch can be repaired by the PCB insert in a shape of original one with plastic reinforcement to keep original thickness. Once greased with specialized chemistry it can work for years.shigeta - Love DigiKey; also use Mouser and/or Newark, but I must admit it takes me quite a while to find Tyco connectors. They allow far too many parameters I don't fully understand in the search.
Thx for the correction on the location of the connector. I did my transmission swap ten years ago and didn't correctly remember that.
As to the creation of a digital alternative for this particular part, I would think there are lots of them laying around given the number of five speed conversions that are done on our cars. By way of example, I have another one. But its a cool project nonetheless.
Good point! My motivation is two-fold:As to the creation of a digital alternative for this particular part, I would think there are lots of them laying around given the number of five speed conversions that are done on our cars. By way of example, I have another one. But its a cool project nonetheless.
In the past it was so called "hard gold" used for contact switches, but also tin on the thick copper should work to keep the cost low. Both can be done currenlty with no technical problems but gold plated contacts would be the most expensive from all options.
