Tail light gaskets
StephenZ
Cumming, GA
What does everyone do for renewing the thick rubber tail light gaskets? Mine are a bit crusty..do they make repops?
Flex seal has a putty that sounds interesting for some of these nla seals...doesn't harden and seals out the weather.. Or maybe use flexseal paste or liquid to repaint the cracked areas of the seals?
I know of no source for these, mine are a bit toasty as well.
If you are going to makeshift, use 3M strip caulk as it is easy to work with and easy to remove. Some say wintergreen oil and alcohol (ratio varies on what you read) and let it soak for a few days. I have Gummi Pfledge which is made for rubber renewal, not convinced it works all that well.
