Rear window gasket lip
StephenZ
Cumming, GA
Anyone who’s done an e3 rear window seal, do you know if I’m assuming the correct lip edge to bring over the inside frame flange? Every other window I’ve done had a very obvious placement and I wanted to be certain..
The circle is where I have my rope imbedded and the arrow points to the inside of the car.. I think it makes sense as the outer flanges step over a couple areas and the inside is just the thin flange area..
That’s what happens when many moons pass before you get back into it..
Good evening Stephen
I have a 74 Bavaria would this rear window gasket my car? If so where did you aquire it? I need both front & rear windshield gaskets.
Thanks Bill G
Yeah, install is easy, just not sure which lip, but I’m pretty certain the one I circled is it. With the tiny anodized ‘lock strip’ that doesn’t seem like much, I don’t want to lose the window over a bump..lol
I got this one new about 9 years ago, along with the front seal..I was lucky.
