Do webers and Solex's use the same manifolds
David
David
Steve Armstrong (@Stevehose) had a set of Weber DCOM carbs mounted to a VGS 52502 manifold. You can see the VGS part number on this picture: https://e9coupe.com/forum/threads/my-vintage-vgs-air-collector-box-project.35860/post-302585. The manifold Shane is selling has this same part number on it, and also is canted toward the rear of the car to move the first carb away from the t-stat housing as Steve's was. I believe Shane's manifold is the same manifold as the one Steve had. Thus, you should be able to mount a set of DCOMs to it.Sorry, I'm referring to side drafts. More specifically will Shane's intake manifold work on my weber DCOM carbs?
Miss you Steve! Great to see your reply.I hope all is well with everyone!
