Thank you, Leveque, I just learned about the baseplate variants, so now I'll have to get a photo of mine. Do you have a photo of yours? Definitely interested. There's also a thread Lucas, another member, who's 3D printing these entire kits. I messaged him to see if he sells a la carte and emailed Al Taylor, too.I have one that would work, came from E3 but they are the same external as far as I know. Let me know if Al doesn't have one. The baseplate is different between the two.
Thank you. I did pick up on what I thought was his overseas location. I didn't confirm, but now I know.Yes Lucas might be able to help, depending on where you are the shipping and tariffs can be the issue. Let me check my baseplates. The E3 ones will work with slight modification I believe. But I’ll send pics.
I will check tomorrow when I visit the shop and let you know what I find out. Thanks!I’ll send pictures this evening of what I have. I just need to keep one for myself but definitely have two evap boxes. One of mine is with the resister for the motor mounted outside the box, the other would have it inside the box. Do you know what your plan is for that?
I 100% would like to purchase these parts. I'm due to the shop this a.m. to survey the needs and will return with my wishes. Any pricing + shipping to 28086, NC, US would be greatly appreciated. DM, if you prefer. I will submit my request(s) later today.Here are pictures of what I have. Both of these boxes have their internals (motor, squirrel cage, evaporator, TXV valve, etc but I had removed all of that. Can send whichever of that you want.
Between the two, one looks a little nicer but has the box on the inside for the resistor. I’d rather sell that one since I’m putting in newer style evaporator core along with some other modifications so don’t need that thing taking up any room. For baseplates, I think I have one E3 (since I pulled it from one) that has that longer extension up front and then two of the same, which I don’t think are for an e9 since they don’t have the small extension, but I do not believe that extra portion actually does anything of necessity, so either of these should work just fine. Let me know if interested, no rush on my end. I also have the duct called the “intermediate piece” which I can sell. It’s OEM, works fine, would need new foam rubber around the outside or felt since the old stuff has disintegrated.
Hi there. My current unit is pictured with the resistor in the middle at the bottom and on the outside on the bottom, broken parts. Also, the plastic piece securing the motor in place is broke.I will check tomorrow when I visit the shop and let you know what I find out. Thanks!
