Boot (trunk)-rear cover
ES 1800
Larsen, WI
Has anyone been able to reproduce this cover for over the rear-most panel of the boot? I have the vinyl but not sure how to create the shape on the top edge, or what material to use. I took what was left of mine to an auto upholstery shop and they could not help me. (Image may not be from an E9 but it was the best I can find.)
While I appreciate the information regarding a source of a competed piece, what I was hoping for was learning if anyone had made the replacement himself or herself. I know of CS Werk and have bought things from him, the current US tariff policy insanity really adds to the cost of bringing in parts.
If you look at the oilsdesigngroup photos, the backside photo essentially shows what cutouts and shape of fiberboard you would need. This part is relatively simple and flimsy, as I recall the top and side are only held together by the vinyl.
I have enough left of the original that I can use as the template. Do you have any idea of a source of the backing material (fiberboard) that is suitable and can be bent to 90 degrees at the top? Or how it is done?
The material is cowlboard, which is waterproof rather than fiberboard which is absorbent. I would do this as two separate pieces of cowlboard, the vertical and the horizontal, cut each of those out and then glue the vinyl to them leaving a 2mm gap to allow the vinyl to make that 90-degree bend at the top. The cowlboard is screwed in with 4 screws on the top side, the lighting fixtures hold it on on the vertical. See https://e9coupe.com/forum/threads/fitting-trunk-lining.46327/
Source for the cowlboard although may be able to find locally near you at upholsterer shop
I agree but with one small twist. Rather than cutting the cowl board through at the bend, score it about half way deep. That will allow it to bend, but it will hold the top and bottom together better than the vinyl alone..
My 2 cents..
View attachment 231097View attachment 231098
I made my own. Unable to find anything like the original, I used a sheet of plastic from Home Depot. I used the old one for guidance. Made a buck like thing out of wood and the old one, then used a heat gun to get the necessary fold. Worked, but not perfect. I doubled up the area around tail lights and top part. Then applied the vinyl. Not the greatest, but desperation drove me to this approach.
