bengal taiga
- Messages
- 224
- Reaction score
- 24
I replaced my Behr viscous fan clutch 6 weeks ago - since it only freewheeled when it warmed up. The replacement Sachs clutch worked fine for a few days and then exhibited the same symptoms (Engages when cold - but freewheels when hot). I returned the clutch and obtained another replacement and was told by the vendor they will not continue to "play games with me" over fan clutches. With the temp gauge in the red, the radiator hoses ballooning, and the engine pinging - demonstrating true overheating issues, I can stop the fan from rotating with only finger pressure. Ergo, this fan clutch is now a useless appendage.
I expect to be adding an electric fan from Summit as a stopgap measure. But with over 25 years of e9 ownership as well as years of owning other cars running viscous fans (Mercedes) I don't believe I should be forced to adapt an electric fan at all. I have researched the issue and noticed several people suggest the viscous clutches can be filled or even refilled with silicone oil to resurrect them. The problem is that these newer clutches do not evidence any leaking oil. Then, there is the issue of grades of oil, oil compatibility, and if there are leak, replacing the leaky seal/s.
Is anyone personally familiar with this process? If so, how would you reattach the bimetallic strip that expands as a valve presumably redistributing the oil to engage the clutch? The Behr uses some sort of putty while the Sachs employs what appears to be a post or rivet connection? What about adding some other substance to permanently lock the clutch (similar to running longer bolts in the original friction fan clutch set up)? Does anyone have or can they point me to a picture or exploded view of the viscous clutch innards? This inquiring mind wants to know!
TIA
TIA
