17'' Alpina's on E9
E9KNZ047
Melbourne Australia
In case you wondered what 17'' Alpina's look like on an E9 here are a couple of pics and some info on the set up.
Fronts are 8'' rims with Dunlop 205 ZR17 50 and rears are 8.5'' Dunlop 235 ZR17 45.
Haven't got offsets to hand but can source if someone wants to know.
The shocks are Bilstein Sports and springs are 25% uprated and 30mm lowered .
A few tuning problems to get the clearances correct. Front hubs have 8mm spacers - the Dunlops have a ridge (inner and outer) that protrudes to protect rims from curb rash - handy but takes up clearance.
Front guards were rolled at the top, also rolled the rear guards as a preventative measure - not sure if rear was required but better safe than sorry.
Rear shocks also had extra spacers put in just to lift the height a little - haven't got the exact measure at hand.
Little bit of mucking around to get the original BMW wheel caps to fit on the rims as the caps where a fraction small in diameter and would slip through - fabricated a slightly larger nylon ring to fit over cap and take up the gap - virtually invisible.
Ride is vastly better than previous 14'' as you would expect - steering is very positive, ride is firm but not harsh - have not had the chance to really give it a country road work out yet - next week.
A few minor rattles now due to the tightened ride but that was expected - will address eventually....
Hope this is of help to others considering 17's
'Apologies' to the purists for this sacrilegeous act :twisted: but I reckon the car has the lines to carry these rims without looking too extreme.
Fabulous.
Definitely interested in the offsets and original fitments (which BMW models) those wheel would have me used on, to aid in sourcing them.
Regards
Jon
Jon - The offsets on the front are 19 and on the back are 14 I have found out.
Sorry but I have no idea what models the 17'' would have originally been found on.
Barry - I got the rims in Australia from Bavarian Motorsport. They can be contacted on email [email protected]. I understand they ship internationally. The guy I dealt with is called Imre - knowledgable and quite pedantic about ensuring the set up was correct - a good thing.
The front 17x8 19mm rims are the later Alpina covered center type and are known as the Alpina "winter wheels" for an e34. The rear Alpina 17x8.5 14mm rims are the standard Alpinas rims found on the front of e34 models. The normal e34 has the 17x9.5 24mm rims in the rear.
What interests me in the fitment of the BMW center cap to the 17" rims. The center covers have been removed and the centers painted black. The 17" Alpina rims have a slighty tapered outer bore but the inner bore is the standard 72.5mm bore. The normal Alpina black plastic cap just falls into the larger 17" slightly tapered bore.
So just how did they get the BMW center caps to fit these 17" Alpina wheels? Maybe there is a way to fit the normal Alpina black plastic cap to these 17" rims? I have not figured that one out yet......Let me know when you figure that one out.
