1971 2800CS Fan Clutch/Water Pump/Fan Upgrade
nobrakese28
Looking to upgrade the clutch/fan assembly on my 2800CS as I prepare to get it back on the road. I've read thorough about a dozen or more threads and they all seem to spiral off.
Can anyone confirm that an E28 535i fan/clutch/water pump combo will be a direct fit onto my E9. I understand the pulley may come into account. Will the original pulley be compatible?
I understand moving to the E28 gets you the large 32mm nut, which is what I am used to anyways.
Marco
Why would you stop at the fan clutch for the e28? It wasn’t good enough for BMW - the e32 fan clutch was the last and best.
my advice is to take the words of @sfdon as the best advice.
cooling v3 = e28 (waterpump, fan clutch, fan and fan shroud
cooling v4 = e32 (fan clutch + fan - no shroud needed) and i believe the e28 waterpump is still the same ... i could be wrong. the only issue is that the fan with the ring around it is from the diesel engines and is hard to get in the USA unless you order it from the EU and pay the tariffs. i got mine from W+N and avoided the tariffs.
Hey guys, thank you. Ordering the water pump, fan clutch and 11-blade fan. Thanks guys.
i have found the fan clutches on several of the websites like fcpeuro, rmeuropean + autohausaz ... the BMW part is very expensive, the Behr part seems to be more reasonable
v3 -
11519070760 - waterpump
11521273086 - fan 9 blade (e28, e24, e23)
11521723918 - fan clutch (e28, e24, e23)
11511271423 - fan pulley 144mm (e28, e24, e23)
17111115083 - fan shroud
v4 -
11522243303 - fan 7 blade (e34, e39, e38)
11527831619 - fan clutch (e34, e32)
11511706781 - fan pulley 130mm (NLA - e30, e28, e34, e24, e23, e32)
yes, but you order a lot of things from the EU ... i have added your previous version (v3) for those that do not want to go thru the trouble to get the 7 blade fan (which is what i am using). FYI, BMW NA does not sell the 7 blade fan in the USA ... and i haven't found any for sale by the aftermarket. i bought mine from W+N before the tariffs affected things - they had the best price.
Hi, I ordered everything for an E32 735I from Rock Auto.
Water pump = Graf (Italy)
Fan = Beck Arnley
Clutch = Beck Arnley
Soooo. It mostly fits, in order to clear the radiator on installation I had to mount the fan on the back of the clutch. It works, it clears, but it leaves me about 1/2" of clearance between the fan and upper radiator hose. The fan is large, but the hood shuts and no issues on first drive. The flan is to machine a register on the back of the fan to center the fan, just being anal. But it works as is. Moves a whole lot of air.
