DP
I concidered this swap when my 1986 E28 M535 died.
The M535 used shock/spring style struts or coil overs for the rear suspension. so the pickup points on the arms, plus the top mounts are different to the E9. Just to add to the whole thing the way the rear brake calipers, differential, and trailing arms are mounted is different so you cannot simply swap components about.
So I would of had to do the following
1.. Cut out the E9 rear diff mounting point. Fabricate /add M535 mount, reinforce as required.
2.. Cut out the M535 rear spring strut top mounts, maybe the whole inner part of the inner wheel housings.
3.. cut out E9 inner wheel arch spring and top shock mounts.
4.. Weld inner top mounts or whole inner arch into the E9 body.
5.. Mount whole M535 rear assembly including driveshafts etc
6.. Modify E9 prop shaft to suit.
only six steps, but a lot of work to ensure it's safe and solid :roll: There are other things to consider including, but not limited to
1.. Route of exhaust
2.. brake lines
3.. handbrake (parking brake) cables
4.. Fuel lines, pump position
5.. Fuel tank (maybe)
6.. The rear track (width) of the assembled M535 rear suspension is wider than a standard E9 set up (I think)
In the end I didn't do it but this is what I think I was going to have to do. Please note this reffers to a 1986 E28 M535 that I had. Other models of E28, including the M5, may be different.
Speaking of which I saw a lovely E28 M5 this weekend, a car I would happily have!
Malc
