HemptasticG
Hello I have currently taken on a E9Coupe restoration, that has previous work done to it. I have a few parts that I don't quite know where the should be located on the car and cant locate them in the www.wallothnesch.com build book. For this post we will call this bracket set A.
is this on of the support brackets for the wooden trunk floor liner. in the image in the wallothnesh.com manual there is only one
#8 is it a LH & RH part.
Now bracket set B, with bracket set A I might have an understanding were B requires to go.
The image of the LH position
Then in the RH position it seams like a previous Tech welded the other bracket in the wrong spot, because the LH bracket wont match the RH.
Ok no that the easy ones are done, now for set C. I have no clue where these go?
Then the last bracket. lets refer to this as set D even tho there is only one.
Thank you and I will appreciate any information or comment.
