Black Friday Sale at 2002sonly.com!
Shop our World Class Products for all Vintage BMWs
and get 10% off on every order over $100 starting November 27th!!
(No Coupon Code Needed, Discount automatically applied at Checkout)
(tii brake boosters not included)
Here are a few examples of our exclusive products for your vintage BMW:
Weber Triple Side Draft M30 | 2002s Only
The M30 Triple Side Draft System is based on the same rock-solid, low maintenance components as the M10 system. It includes everything from the bell crank to the triple Weber throttle shafts. It is $285 plus shipping. Please select either Weber DCOEs or Dellorto DHLAs. NOTE: DOWNLOAD THE...
www.2002sonly.com
Getrag 265 Shift Tower | 2002s Only
BACK IN STOCK AS OF 10/18/2023!The Getrag 265 5-speed, overdrive transmission is the most popular drive train upgrade for the Big Six BMWs (1968 to 1988). For it to work on these cars, a shorter shift platform is required. Those shift platforms have become increasingly rare in the wild, sooo...
www.2002sonly.com
Engine Turning Tool | 2002s Only
This is one tool that every NK, 2002 and New Six owner needs!Need to adjust your valves? Set the dwell angle on your points? Find TDC to stab a distributor?We’ve resurrected the marvelous BMW tool #7008-1. We used 4140 steel and had it hardened to RC 48/52 tool grade steel. We then had it...
www.2002sonly.com
Thank you all for your support!!
