As configured for European use, the CR box came with a tall (like 3.07:1) final drive, so it worked well for the high cruising speeds possible on European highways. This reduced low speed acceleration a little, and fuel economy was not a concern on cars so equipped.
In the US, we don't get to drive 100 mph all day. Lower speed acceleration is more useful (and fun). Mating an overdrive 5 speed to a shorter final drive, like a 3.64, gives you better acceleration and lower cruising speed revs for better fuel economy on the highway. It also lets you lug along in 3rd or 4th gear at any speed between 20 mph and 45 mph, reducing the need to shift constantly in surface street traffic.
A CR box with a short final drive gives you a constant workout stirring gears, and you're still stuck with the 1:1 top gear of the 4 speed you removed. With the wide torque band of the M30, it doesn't make much sense.
Other CR issues -- the "holy grail" factor leads to silly prices. It has a reputation for being weaker than the OD, but that's likely not true -- the CR boxes came behind higher-performance engines, get shifted more, and probably also get abused more.
For my money, the OD box is a better option.
