wmnewlife
Has anyone upgraded the drums from a 2800 CS to 3.0 discs? We are at the engine transmission and front end out stage. The LaJolla lowering kit and 3.5l are at the shop and the 265 arrives Monday. Exciting times.
The springs will make more of a difference in terms of driving enjoyment for that 90% of the time you're driving the car.
i have the same question about replacing rear drum brake to disc in the back of my 2800cs is there any other bmw model which i can take brake from but easier to find part replacement ? eg: e24, e30
also i am not sure what part i need to replace in the suspension whlch is orignal 3.0cs if i want to do a conversion process
thx
The front brakes do the majority of work. Upgrading to vented discs will not increase swept area over solid, but will increase cooling.
My 2800CS brakes where bad until I adjusted the rear drum brake shoes correctly and installed FERODO DS2500 brake pads in front. The braking force was totally changed to the (much) better, and the car feels much safer. No need for vented discs (depends on your driving style of course)!
Henrik
