execmalibu
- Messages
- 629
- Reaction score
- 2
The high beams flash but do not go on with the switch in the up position... It is a Bad switch ,relay, fuses under dash are OK...
Ideas?
Ideas?
Probe the switch/ wires for power. Sometimes just the back is loose and you can restake it. The solder connections on the wires aren't great and work loose if herr assembler was slightly tipsy from beer breaks. I just fixed mine a few weeks ago.
A yel/wht wire from the dimmer goes to the Light switch through a connector.
A wht wire should go from the dimmer to the high beam relay.
A yel should go from dimmer to the high beam light.
The green is Hot (switched) from fuse 6.
You don't have a white wire to energize the HB relay??
