Our 1970 2800CS (2205990) is running very rich at idle and warm up. It spits black soot until it gets warm. Carbs were rebuilt a few years ago and otherwise runs great for 130,00 plus miles. Now are trying trying to figure out why it is so rich during startup and to eliminate the soot on the driveway when starting.
The carbs do not have the electric shut off valves so it does diesel a lot when shut down. The carbs do not have the 'thermostart' cold start valve either. Also it does not have the 'chimney' style vent referenced in the manuals.
The car we believe was bought in Europe as it as the speedo in kilometers. Question is why the carbs are different (missing stuff) that the manuals reference. There are threaded plugs where the shutoff valves are supposed to be. The top portion is not drilled and tapped for the thermo start valve. I do believe the carbs are original in content. The former owner did remove the emssion speed sensor and vacuum damper unit.
I have done a few searched to help fix the problem, but before we dig into the carbs we need to know a little more. We do have a set of carbs from a 72 3.0 CS that do have the shut off valves and the cold start units. If anything is there any reason why we cannot install the shutoff valves and eliminate the terrible dieseling problem?
Thanks,
jjs2800cs
Thanks,
jjs2800cs
