3.0 csi engine turns over but wont star
kevin1972
New Member
Netherlands
I am busy restoring a 1973 3.0 csi
Last week I wanted to start the enige but no succes. When turning the key over the engine turns over but wont start up. I also dont hear the relays kick in and also dont hear the electric fuel pum running. I have checked all the fuses and cant find any thing wrong with the relays. Has anybody got an Idee what it could be. You can answer here or mail me at [email protected]
Thanks guys
Thanks guys
Best offer today is to search in the forum with keywords you think is most likely. Start with "battery" and then go forward.... I think you will get your engine running again.
The accumulated knowledge in this forum could get everything called engine running....:-)
If not that works. Post a further question included functions you have checked.
Regards
Stefan
Hi,
I had this once and it was the relay box that is in front of the manifold absolute pressure canister that is mounted on the inner guard, there ws some tension on the wiring to this silver electrical block that just pulled out enough to kill power to the relays for fuel pump etc...try it??
