Discussing alternator for engine swap
While I can't disagree with what Tilla has written, just to present another side: Why not keep the '72 alternator? While an '86 might have a higher amperage limit, so what? You'll never need those additional amps unless you install power seats, heated cupholders, a 200db stereo, etc. etc. Further, solid state regulators are readily available for early Bosch alternators. They're cheap, foolproof, and bolt-in replacements for the old mechanical regulators.
Keep the '72 alternator, spend $30 bucks on a solid state regulator, and you will achieve reliability without having to fool with the wiring.
My question is: What sort of an induction system are you running with the 3.5 - carbs or FI? Can the original intake manifold & carbs be used with a larger displacement engine?
