I finally made some time to focus on getting my 3.5 rebuild completed and my coupe back together. All of the manifold pieces, covers, oil pan, etc. were all stripped and painted with Endura. I also started to sort out the various fuel injection bits for the conversion I'm doing. Some of you may recall I'm converting it to a GM based ECU, but I'm trying to keep it as stock looking as possible (no bulky AFM or other crap). I'm very pleased with the results. It will take a very sharp eye to notice this is anything but stock D-Jet. So far, I've figured out how to mount a throttle position sensor, the coolant temp sensor, the intake air temp sensor and an idle air bypass valve. This info should be useful for anyone contemplating any type of aftermarket ECU. Here are a few pictures:
Overall view:
Here's the TPS mounted inside the stock D-Jet throttle body. This will be hidden under the stock D-Jet TPS cover:
Here's how the TPS mounts:
The Idle Air Control Valve in the stock warm-up valve location:
Finally, here's the Intake Air Sensor mounted in place of the stock cold-start injector:
I'm going to be running a stock L-Jet distributor which will trigger an MSD ignition box. That, in turn, will trigger the fuel injection. I'll be running fuel only to start out (just like stock D-Jet), but can add ignition control in later once I get the fuel curve programmed. Hopefully I'll have the motor in tonight, then its just a matter of making the wiring harness and getting it all wired up. I'll keep you guys posted.
Overall view:
