Words of wisdom needed. I seem to have fallen down a rabbit hole on this one.
We have a 3.5L motor all rebuilt and ready to drop into our '74 CS project. We pulled the 3.0 motor from the chassis and are now transferring the the ancillaries (oil pan, alternator, Power steering pump, A/C compressor.
The first challenge is the right side motor mount. The block castings are different and it appears the CS bracket won't attach to the block in its proper location (just under #2 spark plug) w/o modifications.
Is there an off-the-shelf right side motor mount that I can use?
Any other things I should know regarding this swap?
(So much for the notion of a "bolt-in" swap. *sigh*)
Thanks, all!
Delia
Thanks, all!
Delia
