4 lug wheel to 5 conversion
dalimizer
Space City
Anyone have any experience converting 2000CS 4 lug wheel to E9 5 lug ?
I remember a post (which I cannot find) giving details on using various 2800cs parts and redriing front rotors. Anyone know or can help?
Thanks.. Jay
A friend of mine did this on his NK sedan, which would have the same front end as a 2000CS. If I recall, the recipe was '77 320i stub axles bolted to the NK strut, with e3/e9 hubs, calipers and rotors. I'll ping him and see if I can confirm.
I know of a 2000cs that was done to years and years ago. My recollection is that the rear was a straight bolt in of e9 swing arms (discs brakes, too!). I do not recall how the front was acoplished. I would ask the owner, but he is no longer with us.....
Re: 5 lug
dalimizer said:
I tried asking seller but he wasnt too helpful
Try calling Boyd Fechner of Fechner Auto Restoration in San Jose California. He's the fellow who did the restoration of that black 2000C.
Re: 5 lug
Is Boyd related to Franz Fechner? He was the owner of the 2000cs I knew of that I was discussing above....
Re: 5 lug
Yes, brothers. Mentioning Franz brings back memories....
Re: 5 lug
Yeah, me, too. I handled his negotiations with the insurance company when Franz rolled his 2000cs coupe at Laguna (and was there that day in my 2002tii). He built another one after that, if I recall correctly.
But, it had 3.0cs trailing arms and five bolt hubs.
This won't work. On both 2000CS/NKs and E21 320i s the "stub axles" are welded to the rest of the strut.
If I were going to try this, I would use the E9 front hubs, 2800CS solid front rotors and see if the 2800CS calipers would bolt on. This may require turning the rotors down slightly to fit. It would require replacing the master cylinder and running an additional brake line to each caliper, but you would definitely have better brakes as the E9 pads are considerably larger.
If that parts mix didn't work I would try just using the whole E9 strut, hub, rotor and caliper.
If someone is really serious about this, I will dig out the parts and see what fits.
_______________
67 2000CS, 70 2002ti, 2 x 72 3.0CS, 77 320i, 633, 635, E30 325i, E46 330Ci ZHP
