My coupe was built with the automatic. Then a 4 speed conversion was in it when the previous owner in Hawaii did all of the performance mods,including now a 5 speed. The shift lever did not hit the surround in either any forward or reverse gear. I decided to buy the UUC short shift kit along with their selector rod (DSSR). They said to cut and weld the DSSR to the correct length once the existing selector rod has been removed. The Creative Workshop is doing the work. We felt it was better to measure the existing rod and have UUC make one to match. The photos below show the DSSR turns out to be 147mm to match the existing rod. The next photo shows the existing shift lever next to the UUC lever. The existing lever has a much bigger dogleg bend than the UUC lever,making the connection point closer to the transmission.
It looks to me that the UUC lever needs a longer DSSR to compensate for the dogleg bend in the existing lever so the shift knob will remain in the same position when going through the gears.
Has anyone done this conversion and had the 2 levers look so different? The Workshop will be installing the parts next week so we'll see if the shift knob ends up close to the original positions when actually driving the car.
