John Buchtenkirch
Thanks to a lot of help from group posts, group members and particularly sfdon I’ve finally made some progress on installing the 5 speed. The aluminum twin mount cross member I bought from the dealer ended up lining up with the entry / extraction slots for the T-bolts so fabricated adapters from ¼” steel that allows me to attach at 2 points on each side of the tranny, one bolt in front of the cross member, a second bolt behind the cross member. I also made two ¼” aluminum spacer washers to raise the transmission the ¼” the adapters dropped the cross member. Some day I may fabricate my own cross member for more ground clearance but first I want to get it on the ground to see if it’s even needed.
I replaced the bell housing studs with bolts, it just makes lining up & sliding in the transmission so much easier.
I also replaced the universal joint / shifter eye on the back of the transmission. I used that old end to extend the bottom of my shifter into a short shifter. So a little bit of welding and fitting in a new $1.76 Oilite bronze bushing from McMaster- Carr and I now have a poor mans short shifter in the car and it seems to work fine.
Now all I need to do is source some greaseable U-joints and get my clutch hose from the dealer and I should be running again :-D:-D:-D. I couldn’t have done it without this group. THANK YOU ~ John Buchtenkirch
