6 new pistons m30 3.3L e3 engine
  • Thread starter Thread starter pp
  • Start date Start date
pp
france
6 new pistons no more available at bmw , these are for special m30 engine of e3
3.3L which is different than a 633 engine ,, 360euro
i will buy them if the size is ok, i need only to know two dimensions:
1 - diameter
2 - high between top of piston and top of piston rod
can you please help with these values ?
see picture, dimensión number "2", is A in the photo
a bientot !
Those are the high compression pistons.
Very hard to find.
I'm not an expert but I suspect that those have to be used with a head that will fit the bump.
I have similar pistons made by Paul Burke and they can only be used with the head that has the designation B35.
That doesn't mean just a head from a 3.5 motor but a head from like a 92 735 as an example.
These are PB pistons for 10.5:1.
1 - diameter
a bientot !
yes i will check dimensions and tell you , just to avoid misunderstanding like for wheels !:: pistons are also in ebay and can be sold any time don't argue me later :) ! ,, tnx
