couttsdesign
The other day I was driving my car home from work and everything was great until I turned on the headlights, specifically the high beams. At that point the car started to stumble and would die if I took my foot off the accelerator. It turns out that I blew the #7 fuse (i.e fuel pump, fuel and temp gauges).
The problem is that the #7 fuse keeps blowing out, even when turning the key to the first ignition position. Where would be a good place to look for the shorted out wire? Is there a link between the headlights and the fuel pump circuits? I'd like to try and fix this myself before giving up and towing the car to my mechanic, so any advice would be greatly appreciated.
thanks,
chris
thanks,
chris
