Buffarea
This is my first post here and hope no one minds a none-coupe post!
My Haynes or Chilton does not mention a seperate procedure for JUST tightening the chain, but heres why I ask.
How much play should there be in my timing chain? I adjusted the valves yesterday and while rotating the crank pulley back and forth noticed what I think is an alarming amount of play in the difference between how much the pulleys move before the cam OR distributor rotor move. I have never noticed a noise from the chain but the car runs eratically, going from powerless to fine, or dieseling after shut off.
I know there are still carb sync issues and I have not timed it with a light yet, but assumed those were the causes until now.
If you have had your valve cover off and rotated the engine, maybe you can share your experience and help me out.
Cheers, Michael
Cheers, Michael
