Jendon2
I have a brake problem can't figure out, it seems my fluid keeps leaking out as I see it on my garage floor as well as the master fluid resolver is continually low
I thought the problem was the hose running from the master cylinder nipple to the cup and replaced that, seemed ok then stated to get a soft pedal again, then within days still losing fluid. then i replaced the rubber grommet on top of master cylinder and the plastic nipple thought would fix it but apparently still leaking cannot figure out where the leak is looks dry by the grommet and new hose and new plastic nipples , could it be a master cylinder internal seal .. it def is coming out a lot but can't quite see where the leak is,, please help
Tired of driving with soft pedal and a can of brake fluid near by.grommet
thanks
Don
thanks
Don
