Ok, started this in another section but title needed to be more specific
74's seem to be different than say a 72.
This car has issues with starting and running then when warm starting and dying.
Does anyone have a wiring diagram that also shows the AC circuits.
The diagram (multi colored) only shows main circuits and does not show the relay for the aux fan that comes on with AC on.
The relay that I have found that is running this is the first relay to the front of the car next to the battery. Different than a 72.
I believe a PO or shop tried to wire the aux fan so it comes on with key on regardless of AC or temp.
When the relay is installed it is hot and I mean it is on regardless of the key. This is why the battery is going dead.
To the right of this relay is the horn relay. Tested. To the right of that #3 relay I'm not sure what it is for. Still trying to determine.
Where the voltage regulator is on most cars and this car the high beam relay is below that. Kind of hidden. See photo.
Then I found and tested three more relays above hood release arm under dash.
Found two of those are not working. That was at 10PM tonight so decided to stop.
So any diagram would be helpful and will get back on it in the morning.
Had a couple more photos but forum won't load any more. Maybe there is a total file size limit?
